BC
3 years agoOpenCL Custom Board porting with Quartus Prime 22.4
I am porting our already ported Stratix 10 GX custom board from 20.4 to 22.4 (the last offical release for OpenCL for FPGA). Everything was ok except I am receiving "Error board.xml: NO_TOP_LE...
hareesh
3 years agoHi,
can you please share error message screenshots. and share project files if it's possible.
- BC3 years ago
Thank you for your response.
Related to the problem I have found that 22.4 has an added entry "board" to "System Info" tab in Platform Designer for component instantiation which is listed as "missing items". It is listed with "default" value but seems it is not the expected value and when Platform Designer opens a qsys file it reports "Error board.xml: NO_TOP_LEVEL_BOARD_XML_NODE" error on the Open System dialog window.
As I said aoc compilation completes without any errors.
Is this sound OK to you.
Thank you for your time
Bulent CANDAN
