Petry_Carlos
2 years agooneAPI on Ubuntu 22.04: make fpga and fpga_sim erro
Hello. I'm testing the oneAPI ToolKit version 2024.0 over a Ubuntu 22.04 server OS. I installed oneAPI according to the "Get the Intel® oneAPI Base Toolkit" from Intel page. Also, I have Quartus P...
BoonBengT_Altera
Moderator
2 years agoHi @Petry_Carlos,
Good to know that you have managed to get rid of the simulation failure.
Suspecting it might be some mis-setup in the environment variable.
As for the compilation flag that you mention on which one to used, below is a references link which explain most of the compilation flag that can be used and with the relevant param:
On the last issues noted, suspecting it might be wrong param passed in for the flags.
Hence please refer to the link above specifically on the Xstarget flag.
Also perhaps would suggest to run a 'jtag config' command to check on the device setup and connection from the host.
Hope that clarify.
Best Wishes
BB
