oneAPI on DevCloud fails on building for FPGAs
- 6 years ago
I have try to run compile the with FPGA emulator and hardware with the command as below:
ssh decloud
git clone https://github.com/intel/BaseKit-code-samples.git
qsub -I -l nodes=1:fpga:ppn=2 -d .
cd BaseKit-code-samples/DPC++Compiler/vector-add/
vi build_fpga_emu.sh
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh
make fpga_emu -f Makefile.fpga
vi run_fpga_emu.sh
#!/bin/bash
make run_emu -f Makefile.fpga
vi build_fpga_hw.sh
#!/bin/bash
make hw -f Makefile.fpga
vi run_fpga_hw.sh
#!/bin/bash
make run_hw -f Makefile.fpga
qsub -I -l nodes=1:fpga:ppn=2 -d . build_fpga_emu.sh
qsub -I -l nodes=1:fpga:ppn=2 -d . run_fpga_emu.sh
qsub -I -l nodes=1:fpga:ppn=2 -d . build_fpga_hw.sh
qsub -I -l nodes=1:fpga:ppn=2 -d . run_fpga_hw.sh
I have saw the output is success by using command "cat".
I will check internally with the related information again.
ssh decloud
#!/bin/bash
vi run_fpga_emu.sh
#!/bin/bash
vi build_fpga_hw.sh
#!/bin/bash
vi run_fpga_hw.sh
#!/bin/bash
- Puya6 years ago
In this scripts I see how you assign a particular node on devcloud for FPGA execution. Apparently not all nodes on the devcloud have FPGA hardware and required tools, you assign nodes with fpga property:
qsub -I -l nodes=1:fpga:ppn=2 -d .I rewrote my scripts modifying qsub as above .
I can compile and run applications on devcloud FPGAs now.
Thank you.
