oneAPI on DevCloud fails on building for FPGAs
- 6 years ago
I have try to run compile the with FPGA emulator and hardware with the command as below:
ssh decloud
git clone https://github.com/intel/BaseKit-code-samples.git
qsub -I -l nodes=1:fpga:ppn=2 -d .
cd BaseKit-code-samples/DPC++Compiler/vector-add/
vi build_fpga_emu.sh
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh
make fpga_emu -f Makefile.fpga
vi run_fpga_emu.sh
#!/bin/bash
make run_emu -f Makefile.fpga
vi build_fpga_hw.sh
#!/bin/bash
make hw -f Makefile.fpga
vi run_fpga_hw.sh
#!/bin/bash
make run_hw -f Makefile.fpga
qsub -I -l nodes=1:fpga:ppn=2 -d . build_fpga_emu.sh
qsub -I -l nodes=1:fpga:ppn=2 -d . run_fpga_emu.sh
qsub -I -l nodes=1:fpga:ppn=2 -d . build_fpga_hw.sh
qsub -I -l nodes=1:fpga:ppn=2 -d . run_fpga_hw.sh
I have saw the output is success by using command "cat".
I will check internally with the related information again.
Yes, there is written:
- Intel Quartus Prime Pro Edition Software Version: 17.1.1
- Open Programmable Acceleration Engine (OPAE) Version: 1.1.2-1
it seems devCloud FPGA toolkits are wrongly installed. and I don't have sudo access to regenerate the OpenCL BSP for newer versions of quartus. So probably another minor version of quartus 17 (maybe 17.1.1) is able to get along with opencl FPGA SDK .
Also it seems at least in my case OPAE is not installed.
Could you please let me know when the issue is resolved?
