kkvasan
4 years agoOneAPi: Iterative read write with swapped memory locations
Hi All, I am using oneAPI to implement an application on Arria 10 GX acceleration card for my research work. There is a long kernel pipeline and input and output memory locations should be swapp...
kkvasan
4 years agoHi Yuguen,
Thanks for the advice.
I have to identify the way to transfer data between kernels through local memory as there is a big compute kernel pipeline consisting of 10s of kernels. will try your suggestion!
Many Thanks,
Vasan
