kkvasan
4 years agoOneAPi: Iterative read write with swapped memory locations
Hi All, I am using oneAPI to implement an application on Arria 10 GX acceleration card for my research work. There is a long kernel pipeline and input and output memory locations should be swapp...
yuguen
4 years agoHey Vasan,
Can you share a report of both versions of your code? (no quartus compile run)
That would be helpful for identifying why you are seeing a throughput drop.
If there is no difference in the reports, it may be that your pipe operations are blocked (trying to read to an empty pipe/to write to a full pipe).
Yohann
