lkljucaric
5 years agooneAPI FPGA Compile Node Errors
I am currently experiencing errors when trying to compile FPGA designs using oneAPI. The errors I'm seeing:
Error: Compiler Error, not able to generate hardware
llvm-foreach: dpcpp: error:...
- 4 years ago
Hi @lkljucaric
I had the same problem which was resolved as follows on advice from Intel.
In the build script add a line at the beginning to ensure that the correct version of Python is used - here is the script I am now using:
#!/bin/bash
export PATH=/glob/intel-python/python2/bin/:${PATH}
source /opt/intel/inteloneapi/setvars.sh > /dev/null 2>&1
make hw -f Makefile.fpgaHope this works for you as well.
Kind regards
Marcus
BoonBengT_Altera
Moderator
4 years agoHi @lkljucaric,
Good day, just following up on the previous clarification.
By any chances did you managed to try on the solution mention by Marcus?
Please do let us know if issues still persist.
Best Wishes
BB
