lkljucaric
5 years agooneAPI FPGA Compile Node Errors
I am currently experiencing errors when trying to compile FPGA designs using oneAPI. The errors I'm seeing:
Error: Compiler Error, not able to generate hardware
llvm-foreach: dpcpp: error:...
- 4 years ago
Hi @lkljucaric
I had the same problem which was resolved as follows on advice from Intel.
In the build script add a line at the beginning to ensure that the correct version of Python is used - here is the script I am now using:
#!/bin/bash
export PATH=/glob/intel-python/python2/bin/:${PATH}
source /opt/intel/inteloneapi/setvars.sh > /dev/null 2>&1
make hw -f Makefile.fpgaHope this works for you as well.
Kind regards
Marcus
BoonBengT_Altera
Moderator
4 years agoHi @lkljucaric,
Thanks for the explanation, can you please let us know which in which node are you facing the issues?
As well as which example design/user guide which you are following, in order for us to simulate the error and understand further.
Hope to hear from you soon.
Best Wishes
BB
