oneAPI compile errors pac_a10
Hi @joeryan,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
A few clarification if I may as below:
1) Based on the compilation command is it correct to you are using the sample design as below? Did you managed to try the same on the latest version?
- https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2BFPGA/Tutorials/GettingStarted/fpga_compile (from version 2022.1)
2) What version and where did you downloaded the oneAPI from? Is the installation completed without error?
- Per my understanding CentOS 7 are having limited support on DPC++ Compiler due to driver incompatibilities and library versioning. Please refer to the link --> https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-base-toolkit-system-requirements.html
Hence would recommended to move to centOS 8 and later version if possible.
Hope to hear from you soon.
Best Wishes
BB
I have not gotten the Sample designs to compile on any version yet, but I am working with the 2022.1 versions of the sample designs. Looking at the supported OS matrix, I'll try a RHEL 8 and Ubuntu 20.04 installation. I was using a guide on using OneAPI and the Intel FPGAs on Centos 7 provided by an Intel FPGA specialist, but will try one of the supported operating systems.
Joe
