OFS : Data Path of QSFP from HE_HSSI
It will be limited due to traffic generator. When you have too much packet to sent, it is impacting the traffic generator to generate the packet needed.
- attdoner1 year ago
Hi @JohnT_Intel ,
With your previous reply "
Unfortunately we do not have the design for the 100G. You will need to build the FIM with this command "./ofs-common/scripts/common/syn/build_top.sh --ofss tools/ofss_config/hssi/hssi_2x100.ofss n6001 work_n6001"
"I had tried this command , and I face the below issue.
sudo hssi hssi_100g
100G loopback test
port: 0
eth_loopback: on
num_packets: 1
gap: none
src_address: 11:22:33:44:55:66
(bits): 0x112233445566
dest_address: 77:88:99:aa:bb:cc
(bits): 0x778899aabbcc
pattern: random
start size: 40
end size: 2580
end select: pkt_num
eth:
continuous mode: off
monitor duration: 0 secNo eth interface, so not honoring --eth-loopback. Try using the hssiloopback command instead.
mbox_write timed out [a]
