attdoner
2 years agoOFS : Data Path of QSFP from HE_HSSI
Hi Team, I am using N6001 with Intel OFS (OFS PCIe Attach) . I wanted to test data transfer from Host1 to Host2 as below. Host1 -> N6001(Port0) -> OtherNIC(Port0) -> Host2. Is there any sample app...
JohnT_Altera
1 year agoHi,
Unfortunately we do not have the design for the 100G. You will need to build the FIM with this command "./ofs-common/scripts/common/syn/build_top.sh --ofss tools/ofss_config/hssi/hssi_2x100.ofss n6001 work_n6001"
- attdoner1 year ago
Hi @JohnT_Intel ,
Thanks for the update, I will compile and get back to you.
Meanwhile, with 10g_hssi tests, I could see throughput difference.TX Packet Count (N6001) TX Throughput(N6001) GB/s 1 25.7812 50 16.0559 500 15.5692 5000 15.5638 50000 15.5708 500000 15.5693 5000000 15.5692 9586980 15.5652 9586981 6.96E-07 10000000 0.643037 1000000000 0.177615 As packet count increases, the throughput decreases. In above table,
For Packet Count 1: The TX throughput = 25Gbps
For Packet Count 50: The TX throughput = 16.05GbpsCan I know why the "throughput" values are lesser for higher packet counts?
