OFS : Data Path of QSFP from HE_HSSI
The reason is that particular FIM is having different Accelerator GUID. I am currently checking to see if we have example design for this testing.
- attdoner1 year ago
Hi @JohnT_Intel ,
Is there any update on example design ?
In addition to my query I have modified few changes in N6001 AFU, but I am facing mbox_write timeout as belowsudo hssi hssi_100g
100G loopback test
port: 0
eth_loopback: on
num_packets: 1
gap: none
src_address: 11:22:33:44:55:66
(bits): 0x112233445566
dest_address: 77:88:99:aa:bb:cc
(bits): 0x778899aabbcc
pattern: random
start size: 40
end size: 2580
end select: pkt_num
eth:
continuous mode: off
monitor duration: 0 secNo eth interface, so not honoring --eth-loopback. Try using the hssiloopback command instead.
mbox_write timed out [a]
