attdoner
2 years agoOFS : Data Path of QSFP from HE_HSSI
Hi Team, I am using N6001 with Intel OFS (OFS PCIe Attach) . I wanted to test data transfer from Host1 to Host2 as below. Host1 -> N6001(Port0) -> OtherNIC(Port0) -> Host2. Is there any sample app...
JohnT_Altera
2 years agoHi,
Are you running " sudo hssistats --clear" to clear the stat? I am able to clear the stat from my side without any issue.
May I know which image are you using for your board? I suspect that you are using 10G FIM which is why it is not able to detect the AFU GUID for it to run the test. The provided image is 2x4x25GbE.
You will need to change the FIM design to 100G design
attdoner
2 years agoHi @JohnT_Intel ,
I have tried " sudo hssistats --clear" still the values used to be there.
We are using https://github.com/otcshare/intel-ofs-fim/releases/tag/ofs-4.1.1.
Yes, Ethernet configurations: 2x4x25GbE.
* Whether the FIM in this link is 10G ?
* Do you use other image for 2x4x25GbE?
* Can we know is there any FIM with 100G ?
