OFS : Data Path of QSFP from HE_HSSI
HI,
I am working internally on this issue. Once I will keep you posted once I have progress on this.
Hi @JohnT_Intel ,
I have found some updation at Mellanox side, by enabling promiscuous mode, I could see the packets in Mellanox.
In Mellanox,
user@user:~$ sudo ifconfig enp1s0f0np0
enp1s0f0np0: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
ether 0c:42:a1:8c:d5:cc txqueuelen 1000 (Ethernet)
RX packets 110 bytes 6600 (6.6 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
But in N6001, hssi stats I could see some random counts(4040438296505124148,....) in statistics parameters as in image. Can you please let me know what are those values?. Even after hssistats is cleared using "--clear", those values still exist under hssistats.
In N6001,
user@user:~$ sudo hssistats
Namespace(pcie_address=None, clear=False)
sbdf: 0000:01:00.0
FPGA dev: {'segment': 0, 'bus': 1, 'dev': 0, 'func': 0, 'path': '/sys/class/fpga_region/region0', 'pcie_address': '0000:01:00.0'}
args.hssi_grps[('dfl_dev.4', ['/sys/bus/pci/devices/0000:01:00.0/fpga_region/region0/dfl-fme.0/dfl_dev.4/uio/uio1'], '0000:01:00.0', 21)]
fpga uio dev:dfl_dev.4
--------HSSI INFO START-------
DFH :0x3000000010003015
HSSI ID :0x15
DFHv :0.5
guidl :0x99a078ad18418b9d
guidh :0x4118a7cbd9db4a9b
HSSI version :2.0
Firmware Version :16
HSSI num ports :4
Port0 :25GbE
Port1 :25GbE
Port2 :25GbE
Port3 :25GbE
--------HSSI INFO END-------
HSSI num ports: 4
HSSI Ports | port:0| port:1| port:2| port:3|
tx_packets |4040438296505124148|4040438296505124148|4040438296505124148| 110|
rx_packets |4040438296505124148|4040438296505124148|4040438296505124148| 6|
rx_crc_errors | 3735929054| 3735929054| 3735929054| 0|
rx_align_errors | 0| 0| 0| 0|
tx_payload_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 5060|
rx_payload_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 950|
tx_pause |16045693110842147038|16045693110842147038|16045693110842147038| 0|
rx_pause |16045693110842147038|16045693110842147038|16045693110842147038| 0|
rx_errors | 3735929054| 3735929054| 3735929054| 0|
tx_errors | 3735929054| 3735929054| 3735929054| 0|
rx_unicast |13644642147974742460|13644642147974742460|13644642147974742460| 0|
rx_multicast |13644642147974742460|13644642147974742460|13644642147974742460| 4|
rx_broadcast |13644642147974742460|13644642147974742460|13644642147974742460| 2|
tx_discards | 0| 0| 0| 0|
tx_unicast |13644642147974742460|13644642147974742460|13644642147974742460| 110|
tx_multicast |13644642147974742460|13644642147974742460|13644642147974742460| 0|
tx_broadcast |13644642147974742460|13644642147974742460|13644642147974742460| 0|
ether_drops | 3735929054| 3735929054| 3735929054| 0|
rx_total_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 1058|
rx_total_packets |4040438318920698472|4040438318920698472|4040438318920698472| 6|
rx_undersize | 3735929054| 3735929054| 3735929054| 0|
rx_oversize | 3735929054| 3735929054| 3735929054| 0|
rx_64_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 0|
rx_65_127_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 4|
rx_128_255_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 0|
rx_256_511_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 2|
rx_512_1023_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 0|
rx_1024_1518_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 0|
rx_gte_1519_bytes |16045693110842147038|16045693110842147038|16045693110842147038| 0|
rx_jabbers | 3735929054| 3735929054| 3735929054| 0|
rx_runts | 3735929054| 3735929054| 3735929054| 0|
- attdoner2 years ago
Hi @JohnT_Intel ,
In addition to above queries, the Transfer rate shows throughput nearly 25Gbps for 10G using 'sudo hssi hssi_10g --num-packets 1 '. But when I execute for 100G, I could see error message. Can I know what causes this issue? How to resolve this error?
$ sudo hssi hssi_100g --num-packets 10[hssi_100g] [error] no accelerator found with id: 43425XX6-9XX2-3XX2-bXXa-aXXX4b53XXX2
