Now I am familier with PAC software and have a question
question: When I am installing the openvino for PAC(of Arria 10), there is no such selection. Then I selected (2), but there are many warning and error
montage-Purley# ./install_openvino_fpga_dependencies.sh
Getting OpenVINO Information
Would you like to setup an FPGA? Select an option below.
Select (1) for None, (2) Intel® Arria® 10 GX FPGA Development Kit, (3) for Intel® Vision Accelerator Design with Intel® Arria® 10 FPGA (IEI Mustang-F100-A10):
1) none
3) Intel® Vision Accelerator Design with Intel® Arria® 10 FPGA (IEI Mustang-F100-A10)
#? 2
Selected: Intel® Arria® 10 GX FPGA Development Kit
The NEO OpenCL GPU driver is required for using the GPU with OpenVINO. Would you like to install it?
Please select (y/n)
y
Do you want to setup a Movidius Neural Compute Stick?
Please select (y/n)
y
Do you want to setup an Intel® Vision Accelerator Design with Intel® Movidius™ VPUs card?
Please select (y/n)
y
Install NEO OCL
Intel OpenCL graphics driver installer
Looking for previously installed user-mode driver...
dpkg-query: 没有找到与 intel-opencl 相匹配的软件包
dpkg-query: 没有找到与 intel-ocloc 相匹配的软件包
dpkg-query: 没有找到与 intel-gmmlib 相匹配的软件包
Found intel-igc-core installed, uninstalling...
dpkg: 依赖问题阻止了卸载 intel-igc-core 的操作:
intel-igc-opencl 依赖于 intel-igc-core.
dpkg: 处理软件包 intel-igc-core (--purge)时出错:
依赖问题 - 不会执行卸载
在处理时有错误发生:
intel-igc-core
ERROR: unable to remove intel-igc-core
please resolve it manually and try to launch the script again.
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
libjson-c2 已经是最新版 (0.11-4ubuntu2)。
libusb-1.0-0 已经是最新版 (2:1.0.20-1)。
libboost-filesystem1.58.0 已经是最新版 (1.58.0+dfsg-5ubuntu3.1)。
libboost-program-options1.58.0 已经是最新版 (1.58.0+dfsg-5ubuntu3.1)。
libboost-thread1.58.0 已经是最新版 (1.58.0+dfsg-5ubuntu3.1)。
libssl1.0.0 已经是最新版 (1.0.2g-1ubuntu4.15)。
libudev1 已经是最新版 (229-4ubuntu21.22)。
升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 151 个软件包未被升级。
./install_openvino_fpga_dependencies.sh: line 371: /deployment_tools/inference_engine/external/hddl/generate_udev_rules.sh: No such file or directory
sed: can't read /etc/udev/rules.d/98-hddlbsl.rules: No such file or directory
[Error] Can't find path to HDDL-R drivers. Skipping HDDL-R setup.
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
libelf-dev 已经是最新版 (0.165-3ubuntu1.2)。
[Error] Quartus not find. If it's installed, try 'sudo updatedb' and re-run this script. Otherwise install Quartus and re-run.
[Info] Warning: multipe multiple Quartus instances found!
Size of array: 0
Installing aocl flash fix to: /linux64
[Error] If you want to use the aocl flash utility: install Quartus and run this script again.
Cannot find board_env.xml in /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1
The ./install_openvino_fpga_dependencies.sh script that you reference is from fpga_support_files.tgz and is NOT applicable to the PAC. This is not clear in the documentation. We will get this addressed.
You can safely ignore the fpga_support_files instructions when using the Arria 10 PAC.
