Need library for 32 bits app on DevCloud ( for vsim)
- 5 years ago
Hi @MGRAV,
Noted and thank you for your feedback, now it is clearer to me, indeed the ubuntu are not supported, references for the support OS for HLS can be found here (CentOS is one of them).
Good to know that it is working now, with that we would be closing the thread and transitioned to community support.Best Wishes
BB
Hi Mathieu,
Thanks for the quick response. It's evident that you are using FPGA Devcloud from the links which you shared. This forum is intended to handle oneAPI devcloud issues. We have a dedicated forum ( Intel® High Level Design Forum ) to handle FPGA related issues. So, we are moving this thread to Intel high level design forum where the experts in FPGA will guide you in your query.
Please follow up your query in the below link:
Chithra
- BoonBengT_Altera5 years ago
Moderator
Hi @MGRAV
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
Quick check, is this issues still persisting? Clarification is the error happening on the devcloud or on your local machine where HLS are installed? If in devcloud in which node are you trying to connect to to run the HLS emulation? What are the command that you have executed which gets the error mention?Suspecting that modelsim might not be installed maybe? If that is the case, it can be download in the following link here. (i.e. please do select the appropriate version accordingly)
Warm regards.
BB- MGRAV5 years ago
Yep, the problem si still around, and yes on the devcloud.
To connect I use the script as stated here : https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions
I use the devcloud_login and tools_setup, so it's not always the same nodes, but for example now I am connected on the s005-n004 and no ways to make it work. But end December, early January I try many nodes and the problem look to be common to each one.
Best,
Mathieu
Moderator
Hi @MGRAV,
Apologize for the delay in response, by any chances did you managed to try the steps to download and installed the modelsim tool?
The error message seems to be stated that the tools are missing.
Please do try out and let us know if any difficulties after that.Warm regards
BB
