Beginner_in_FPGA
Contributor
2 years agoN6000-PL is not showing up in 'lspci'
Hey, I have with me the N6000-PL card which was provided by Intel. And am trying to test the card as is by connecting to a Dell PowerEdge R520 Server. This server is populated by a single CPU hence...
Beginner_in_FPGA
Contributor
2 years agoHi @khtan,
No the card hasn't been programmed yet I'm in the process of building the BMC.
I will try pcie_aspm=off and let you know if it works. But before this I would rather confirm with the programmed board than this.
Thank you,
Best Regards
KianHinT_altera
2 years agoHi,
Just checking up on this, did you still see the AER error after programming the card?
Kian
- Beginner_in_FPGA2 years ago
Contributor
Hi @khtan
Even after programming the board AER error shows up. On RHEL 8.6 it doesn't show up. But in Ubuntu 22.04 the error pops up on bootup. I am yet to try with the below mentioned commands since I shifted to RHEL to build the BMC, will confirm with it on Ubuntu with the commands and let you know.
pcie_aspm=off
sudo update-grub
Thank you,
Best Regards.
