[N3000 setup] Pr Interface ID: eeeeeeee-eeee-eeee-2222-222222222222
- 5 years ago
The acceleration stack you are trying to install is for this board:
While you have this board:
You should install this acceleration stack instead:
Note that if OpenCL support is what you are looking for, there is no OpenCL support for the N3000 board as far as I am aware.
- E-Hong5 years ago
If I install solely the first link mentioned by you, I am unable to run `aocl diagnose`, that's how I ended up installing both. Thanks for the clarification!
My goal is to run deep learning inference targeting `HETERO:FPGA,CPU`, is the N3000 PAC capable of doing this?
Another question, how do I run `aocl diagnose` on the N3000 pac? And, if I installed only N3000 Acceleration Stack, `sudo fpgainfo fme` is not working as well.
Thank you.
