Noman3
1 year agoModular approach for the NIOS ii processor intigration with main FPGA file
I am currently working on integrating the Nios II processor with the main VHDL file in Quartus Prime. So far, I’ve successfully implemented PWM signal generation by assigning a constant angle using t...
- 1 year ago
Hi
One method is you could just add in multiple PIO IP and lock the addresses.
This can be done by clicking the little lock icon.
The Addresses of the PIO IP will be fix if you add in additional IPs to the project, this will not mess up the base address of the PIO IPs.
Jingyang, Teh
tehjingy_Altera
1 year agoHi
Do you have any follow up question on this?
Jingyang, Teh
