agond2
6 years agoMissing FCD entry on Devcloud nodes 81-87
I am trying to run OpenCL applications on Devcloud FPGA nodes, it seems FCD entry is missing for nodes 81-87 aocl diagnose command returns following: -----------------------------------------------...
MEIYAN_L_Intel
6 years agoHi,
I am checking internally the information with developer.
In the mean time, could you provide the full command you had used when you compile the OpenCL application?
agond2
6 years agoI used the command aoc -v <kernel name>.cl to compile the .cl file.
I get the same error as discussed in the other forum post https://forums.intel.com/s/question/0D50P00004bTqr9SAC/devcloud-unable-to-compile-for-fpgas-aoc-quartus-is-not-on-the-path :
aoc: Quartus is not on the path!
aoc: Is it installed on your system and quartus bin directory added to PATH environment variable?
