Memory Conflicts in onchip ram
There's some mistake in the previous code posted. Done modified as below:
int main() {
int i = 262144;
unsigned int addr;
unsigned int result;
for (addr = BASE_ADDRESS; addr <= 0x40019; addr+=4) {
IOWR_32DIRECT(addr, 0x4, i);
i++;
for (result = BASE_ADDRESS; result <= 0x40019; result++ ) {
printf("Address: 0x%x, Value: %d\n", result, IORD_32DIRECT(result, 0x4));
printf("Address: 0x40016, Value: %d\n", IORD_32DIRECT(0x40016, 0x4));
printf("Address: 0x40007, Value: %d\n", IORD_32DIRECT(0x40007, 0x4));
return 0;
Terminal screenshot below:
Address part is increasing correctly and can read value outside the loop correctly. Ya, you're right can pass directly the numerical value.
You can checkout this link https://fys4220.github.io/part-exercises/exercises_memory_mapped_sw.html on byte-oriented offset for IOWR_32DIRECT and IORD_32DIRECT
Sheng
- ggxnd3 years ago
My question is does the same works for 2MB address location of OCR. What if the end address is increased so that it writes 2MB location?
