sRama28
6 years agoMAX10 -FPGA image remote update using QSPI
i want to update FPGA sof/pof with new programmed rpd file from remote PC. Q1.Shall i use QSPI device to update the MAX 10 FPGA image or internal CFM flash for that update? Q2.if QSPI is ok to upd...
sRama28
6 years agohi Sooy
thanks for the reply.
i want to update MAX10 CONFIGURATION FLASH MEMORY (CFM) using NIOS processor with the help of Ethernet protocol .the example you have shared is UART.
Q1.Shall you share Ethernet based Remote update project?
