sRama28
6 years agoMAX10 -FPGA image remote update using QSPI
i want to update FPGA sof/pof with new programmed rpd file from remote PC. Q1.Shall i use QSPI device to update the MAX 10 FPGA image or internal CFM flash for that update? Q2.if QSPI is ok to upd...
YuanLi_S_Intel
6 years agoHi,
Yes, you will need to use NIOS II with that. You may refer to the following user guide for the flow to implement that.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
ALso, we have a how-to-video to perform that. Just in case if audio is more effective than reading.
