Matrix_mul in FPGA Only warning coming up
Trying to run matrix_mul in fpga. Followed same procedure mentioned in Vector add, made build_fpga_hw.sh and run_fpga_hw.sh and then
qsub -l nodes=1:fpga_compile:ppn=2 -d . build_fpga_hw.sh
qsub -l nodes=1:fpga_runtime:arria10:ppn=2 -d . run_fpga_hw.sh
This warning came up..
:: WARNING: setvars.sh has already been run. Skipping re-execution.
To force a re-execution of setvars.sh, use the '--force' option.
Using '--force' can result in excessive use of your environment variables.
usage: source setvars.sh [--force] [--config=file] [--help] [...]
--force Force setvars.sh to re-run, doing so may overload environment.
--config=file Customize env vars using a setvars.sh configuration file.
--help Display this help message and exit.
... Additional args are passed to individual env/vars.sh scripts
and should follow this script's arguments.
Some POSIX shells do not accept command-line options. In that case, you can pass
command-line options via the SETVARS_ARGS environment variable. For example:
$ SETVARS_ARGS="ia32 --config=config.txt" ; export SETVARS_ARGS
$ . path/to/setvars.sh
The SETVARS_ARGS environment variable is cleared on exiting setvars.sh.
Can anyone please tell me where i am going wrong and what should be done..?
thanks for any help..
