Manual simulation of a HLS design failed
- 5 years ago
I'm replying to my own topic for resolving the issue. The problem was the .do file that is generated when executing NativeLink testbench from Quartus marks the source files generated by HLS Compiler as Verilog 2001 instead of SystemVerilog. Perhaps because the files are with the .v extension instead of .sv, even though they contain SystemVerilog specific code?
Replacing all of the -vlog01compat with -sv option in the .do file (and then running the .do file again in ModelSim) allowed the execution of the test bench.E.g.:
vlog -sv -work work +incdir+C:/../dsp_hls_streams.prj/quartus {C:/../dsp_hls_streams.prj/quartus/quartus_compile.sv} vlog -vlog01compat -work dsp_hls +incdir+c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules {c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules/acl_arb_intf.v} vlog -vlog01compat -work dsp_hls +incdir+c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules {c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules/acl_avm_to_ic.v}
Replace with -sv:vlog -sv -work work +incdir+C:/../dsp_hls_streams.prj/quartus {C:/../dsp_hls_streams.prj/quartus/quartus_compile.sv} vlog -sv -work dsp_hls +incdir+c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules {c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules/acl_arb_intf.v} vlog -sv -work dsp_hls +incdir+c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules {c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules/acl_avm_to_ic.v}
This happens because Quartus Prime Lite v20.1.1 does not support HLS. Try using Quartus Prime Lite v19.1 and install the HLS compiler for that version here: https://fpgasoftware.intel.com/19.1/?edition=lite&platform=windows
For your information starting from version 20.1, HLS is not supported on Quartus Standard and Lite edition. If you want to use HLS on the latest version you'll have to use the Pro edition.
Nurina
