'make fpga_sim' Errors in Getting Started with oneAPI
Hi Runlong.
What does it say in the vector_add_fpga_sim.log file?
Did you make sure to install the correct Quartus device files? This error often occurs if you didn't download the FPGA device files; there will be a note about missing Agilex™ 7 Device files in the log file.
You can download the Agilex™ 7 device support from the FPGA Software Download Center:
Look under 'Individual Files' and select the Agilex™ 7 Device support files:
- uniqueMR2 years ago
Hi whitepau,
I checked the vector_add_fpga_sim.log file, and it reports some license issue. I've already configured the LM_LICENSE_FILE variable but without the other two (SALT_LICENSE_SERVER and MGLS_LICENSE_FILE). With my LM_LICENSE_FILE, I have full access to Quartus Prime Pro 24.1 with Agilex 7 device support. What should I do with the other two to support oneAPI workflow?
I also checked my Quartus device files and found that both Agilex 7 device support and Agilex common files had been installed.
Do you have any other clues on resolving this issue? Thanks a lot.
Runlong
- whitepau_altera2 years ago
Contributor
Thanks for sharing the log file.
That appears to be a questa license issue. We have documentation here on how to get a 0-cost Starter Edition license: https://www.intel.com/content/www/us/en/docs/programmable/683472/24-2/and-software-license.htmlWe are working on getting the installer to handle the questa license for you in the future.
Hi whitepau,
I've generated the license for questa starter edition and configured the environmental variable in my ~/.bashrc, but it still reports the same issue:
Below is how I configure the license file in ~/.bashrc:
and also the content of my license file to make sure I get the proper one:
I attach my current sim report to this thread. Are there any clues on further resolving this issue? Thanks a lot.
Runlong
