LMI interface in Intel Arria 10 Avalon Streaming Interface for PCI Express
- 4 years ago
We do not receive any response from you to the previous answer that I provided.
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
Can you please make sure that, whether LMI interface signal can be used for root port configuration space register write operation?
- LMI Write operations are provided for AER header logging, and debugging purposes only if refer to the user guide
From what I understand, the lmi_ack (Acknowledge signal) normally will sent back when execution is complete.
Can you please check back is anything wrong with the execution part?
Wincent_Intel
Hi Wincent_Intel,
But we are using LMI write for Root port configuration space register operation, may be for that reason it is not working??
