TRahm3
7 years agoLinking top level RTL function with all its required modules using the OpenCL RTL library workflow
I have a top level verilog function, within it I instance some other modules. I have written the xml file and c_model as well as calling the top level verilog function in my OpenCL kernel (following ...
KennyT_altera
7 years agoIf you look into the example 2
<directory>\library_example2\device, you see the example2.cl.
This is the top level files that you can follow. You can look inside the lib files how they link btw *.cl and *.v code.
