zjinf
7 years agoLatest BPS for Stratix 10 on Quartus prime pro 18.1 .0.222 ???
my environment is: board: Stratix 10 development board aocl: aocl 18.1.0.222 (Intel(R) FPGA SDK for OpenCL(TM), 2.my question is : In diagnose hint , it says my board is s10gx_ea in m...
MuhammadAr_U_Intel
Contributor
7 years agoI believe issue here is your board flash is programmed with older image (18.0) however latest .aocx is build with new compiler build (18.1)
Try updating the flash by aocl flash <acl0> <new.aocx>
Hope this helps.
Arslan
zjinf
7 years ago- with 18.1 (s10gx) aocl install by root . after aocl install command , when i run "aocl diagnose " command, it can't detect the board (but aoc command can generate s10gx *.aocx file ),DIAGNOSTIC_FAILED, can't detect device , I can do nothing.
and i turn back to (s10gx_ea), it can diagnose successful.
2 . after aocl flash acl0 <my_s10gx.aocx> successfully , i still can't run the host file .
all i did just flow the "S10_DevKit_Initialization_18.1.pdf" in intelFPGA_pro/18.1/hld/board/s10_ref/bringup directory
