Issues with the use of the flag "-fintelfpga"
I had find the an useful link which have provide information for compilation in SYCL:
https://github.com/intel/BaseKit-code-samples/blob/master/DPC%2B%2BCompiler/FPGATutorials/Compilation/compile_flow/README.md
You could find the files directory in Devloud with link below:
https://github.com/intel/BaseKit-code-samples/tree/master/DPC%2B%2BCompiler
I had tried the command but there is some permission denied to view the report.
The permission denied is use to prevent IE from issuing "block content".
- FelipeML5 years ago
Hi all and thanks in advance for any help that you could provide.
It seems that the problem with which I opened this thread is still unsolved, and we have just found a modification that seems to narrow down the problem.
We've been playing with the following code that is one of the examples available in the oneAPI training material:
using namespace sycl;
int main()
range<1> r{SIZE};
#ifdef FPGA_EMULATOR
INTEL::fpga_emulator_selector device_selector;
#else
INTEL::fpga_selector device_selector;
#endif
queue q{device_selector};
queue q_cpu{cpu_selector{}};
buffer<int, 1> a_buf{r};
buffer<int, 1> b_buf{r};
buffer<int, 1> c_buf{r};
// a ---- c --- d
// b __/
q.submit([&](handler& h) {
accessor a(a_buf, h, write_only);
h.parallel_for(r, [=](auto idx) {
a[idx] = idx; });
accessor b(b_buf, h, write_only);
b[idx] = -idx; });
q_cpu.submit([&](handler& h) { //fails with q_cpu, but not with q
accessor a(a_buf, h, read_only);
accessor b(b_buf, h, read_only);
accessor c(c_buf, h, write_only);
c[idx] = a[idx] + b[idx]; });
accessor c(c_buf, h, read_write);
c[idx] += 1; });
}).wait();
std::cout << "DONE.\n";
return 0;
}As you can see in the comment of the 3rd kernel submission, submitting in the same code to the FPGA and the CPU at the same time and expecting the runtime to solve the data flow dependencies fails with the following message:
u32284@s001-n081:~/oneTBB/examples/SC20/lab$ dpcpp -fintelfpga vector-add-fpga.cpp -DFPGA_EMULATOR -o vadd.emu
u32284@s001-n081:~/oneTBB/examples/SC20/lab$ ./vadd.emu
terminate called after throwing an instance of 'cl::sycl::runtime_error'
what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
AbortedIf we change the second kernel so that we avoid submitting to the CPU device, the code does not return:
// change q_cpu.submit()... by this:
host_accessor a(a_buf, read_only);
host_accessor b(b_buf, read_only);
host_accessor c(c_buf, write_only);
for(int idx=0; idx<SIZE;idx++){
}And the only way to get it works, as far as we know, is by destroying the host_accessors:
}u32284@s001-n081:~/oneTBB/examples/SC20/lab$ dpcpp -fintelfpga vector-add-fpga3.cpp -DFPGA_EMULATOR -o vadd.emu
DONE.
u32284@s001-n081:~/oneTBB/examples/SC20/lab$Has this been reported before? Are we doing something wrong or is the compiler/runtime that still needs some improvements?
Thanks once again.
- KennyT_altera5 years ago
We are sorry to inform that if this thread had been close from Intel quite a while a go. This thread had been transitioned to community support.
If you would require further support from intel, you will need to open a thread on this.
Best regards,Kenny
A new thread on this
