FelipeML
6 years agoIssues with the use of the flag "-fintelfpga"
Hello! We are trying to use the emulator to check the results of an algorithm and we have found that the execution fails when we use the "-fintelfpga" flag. The running example is a simple "triad" ...
FelipeML
6 years agoHi again!
I just found in the documentation a section where it says explicitly that we should "Use the following command to compile for emulation: dpcpp -fintelfpga *.cpp"
https://software.intel.com/en-us/oneapi-programming-guide-offline-compilation-for-fpga
Thank you for your help.
