Issues with the use of the flag "-fintelfpga"
Hello!
Thank you for the attention.
The specific example I was referring to was the one in: https://devcloud.intel.com/oneapi/get-started/base-toolkit/
In the Vector-Add example when we do "make fpga_emu -f Makefile.fpga" we are using "-fintelfpga" to compile when we want to use the emulator.
In addition, the -fintelfpga flag to use the emulator is also used in all the examples that use FPGA within the BaseKit-code-samples/DPC++Compiler folder. For example, in "FPGATutorials/BestPractices/double_buffering/" when using "set(EMULATOR_COMPILE_FLAGS"-fintelfpga -DFPGA_EMULATOR")" in the CMakeLists.txt, as well as in all other examples in the "FPGAExampleDesigns/" and "FPGATutorials/" directories.
So I assumed that the use of "-fintelfpga" is necessary to use the emulator.
Regards.
