Nick's avatar
Nick
7 years ago
Issue running OpenVINO 2019.1 classification sample on Arria 10
I am working with an Arria 10 PAC card in a server running RHEL 7.6. I have ensured the firmware on the PAC is up to date (1.2) and am using the fpga_2019.1.133 release of OpenVINO. I followed the steps outlined at https://docs.openvinotoolkit.org/latest/_docs_install_guides_PAC_Configure_2019R1.html and get to the point of attempting to run the classification_sample with the -d HETERO:FPGA,CPU flag. The same script appears to run fine in CPU only mode. Here is the error output.
[ INFO ] Loading model to the plugin
FAILED to read auto-discovery string at byte 44. Full auto-discovery string value is 17 c12babe577632f8d6172495d8daa78017e42fb2a pac_a10 0 0 2 1024 0 4294967296 4294967296 8589934592 0 7 DLA_VERSION_4_4x2x16x64_fp11_sb18823_i1_actk8_poolk8_owk8_image224x224 0 128 0 0 1 0 1 0 0 0 0 1 1 1 3 1 1 1 0 bias_reader 256 128 0 0 1 0 1 0 2 2 1 8 2 1 8 0 0 1 1 1 3 1 1 1 0 config_reader 512 128 0 0 1 0 1 0 2 2 1 8 0 0 4 0 0 1 1 1 3 1 1 1 0 filter_reader 768 256 0 0 1 0 1 0 6 2 1 8 2 1 8 0 0 4 0 0 4 0 0 4 0 0 4 0 0 1 1 1 3 1 1 1 0 input_reader 1024 128 0 0 1 0 1 0 4 2 1 8 2 1 8 0 0 4 0 0 4 0 0 1 1 1 3 1 1 1 0 output_writer 1280 128 0 0 1 0 1 0 2 2 1 8 2 1 8 0 0 1 1 1 3 1 1 1 0 perf_writer 1536 128 0 0 1 0 1 0 1 2 1 8 0 0 1 1 1 3 1 1 1 0
acl_hal_mmd.c:1393:assert failure: Failed to initialize kernel interfaceclassification_sample: acl_hal_mmd.c:1393: l_try_device: Assertion `0' failed.
Aborted (core dumped)
I can provide the output of the test commands I ran leading up to that error if that helps.
  • JohnT_Altera's avatar
    JohnT_Altera
    May I know if you are able to switch it to CentOS, Ubuntu or Yocto as this is the tested OS for OpenVINO?
    • Nick's avatar
      Nick
      If will see if that is possible with a spare server however my target environment has to be Red Hat. Is there anything that can be checked/confirmed on the existing installation?
    JohnT_Altera
    Currently we have only verified the OpenVINO and PAC card in the 3 OS. Let me try out to see if I am able to make it work in Redhat OS.
    JohnT_Altera
    May I know if you are able to make it work from your side?
    • Nick's avatar
      Nick
      John, I believe the culprit on my system was a reference to an OpenCL instance from a previous (2018.x) version of OpenVINO. After I repaired the 2019 R1.1 installation and pointed the INTELFPGAOCLSDKROOT environment variable to /opt/altera/aocl-pro-rte/aclrte-linux64 I was able to get a result using the classification sample running on the PAC. Thanks for the help.
  • Shawn_S_Intel's avatar
    Shawn_S_Intel
    This can happen if you are not using the 18.1.2 OpenCL RTE. Intel Acceleration Stack v1.2 installs RTE 17.1.1 so this can easily happen. The IAS init_env.sh script will be pointing to this 17.1.1 RTE.
    OpenVINO 2019.R* installs the correct OpenCL RTE for the OpenVINO FPGA bitstreams (perhaps in /opt/altera/aocl-pro-rte). Make sure that your initialization scripts point to it rather than to the OpenCL RTE that is installed with IAS 1.2.
