Is there any good source for HLS with a very basic example?
I am intending to learn HLS, buy on internet, I couldn't find any good example or tutorial that describes a simple go through with Intel HLS.
Please note that I am an experienced Verilog and VHDL designer. Just need a good go through with Intel HLS tools and do a simple example on Windows platform.
Please post if there is any.
Thanks in advance
- MEIYAN_L_Intel
Thanks for the provided the information above.
I found there is a information error as stated "The Intel® HLS Compiler is included in the Intel® Quartus® Prime Design Software installation and is supported by the Quartus Prime Pro Edition, Quartus Prime Standard Edition, and Quartus Prime Lite Edition" in link below:
https://www.intel.com/content/www/us/en/software/programmable/quartus-prime/hls-compiler.html
As the HLS compiler is not included and supported in Quartus Prime Lite edition.
I will report this information to the concern team.
- TRoa
Thanks for update sir.
- MEIYAN_L_Intel
There is a simple design example which is compile in Window in 2.2 with the link below: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-getting-started.pdf
For you information, you may also find other examples in the path: <quartus_installdir>\hls\examples
- TRoa
Thanks for replay. Another related question. Is there any way I can learn HLS for free? Is for Pro version, I will be needing a paid licence. And light version doesn't contain any HLS option.
- MEIYAN_L_Intel
Question:
"Is there any way I can learn HLS for free?"
Answer:
You can learn through training course provided by Intel with link below:
https://www.intel.com/content/www/us/en/programmable/support/training/catalog.html?courseType=Online
Question:
"Is for Pro version, I will be needing a paid licence. And light version doesn't contain any HLS option."
Answer:
Based on my understanding, there is more feature and option build for HLS compiler pro edition compare to HLS compiler lite edition.
- TRoa
I couldn't find any HLS compilers Lite version so far. I am trying, may be I could find. As I downloaded Lite version of Quartus, and that doesn't included HLS compiler. But may be there is some separate support is provided for Lite version users.
- HRZ
You can probably install Quartus Prime Standard or Pro and play around with the HLS compiler since, as far as I know, the C/C++ to HDL compilation does not need a license. You should also be able to run simulations without a license. However, to place and route the HDL into a bitstream and run on an actual FPGA, you are going to need a license.
