Is Spatial IP ready for LLM / transformer inference?
Currently FPGA AI Suite 2026.1.1 (with the new spatial compiler) doesn't support LLM / transformer inference.
Could you please clarify:
- Is LLM inference unsupported across all FPGA AI Suite releases, or is this something being actively worked on for a future release?
- Can I confirm that the standard FPGA AI Suite workflow is not supported for LLM / Transformer models on the Agilex 5 E-Series 065B Modular Development Kit?
The workflow I am referring to is:
Hugging Face model(optimum-intel) → OpenVINO IR (.xml + .bin) → architecture_optimizer → dla_compiler (Sequential flow) or Spatial Compiler → Integrate the generated FPGA AI Suite IP into a Quartus Prime project → Generate the bitstream and program it onto the Agilex 5 E-Series 065B board → Run inference using the FPGA AI Suite runtime (host application).
I understand this may not be a push-button process and could require significant modifications to the generated RTL — but is this workflow still considered a viable starting point for implementing LLM / Transformer inference on the Agilex 5 E-Series 065B?
Thank you very much.
