TKlei
7 years agoInterfacing DDR3 with DSP Builder. Adressbus size?
Hi, I'm using DSP Builder with External Memory Write block to store data in an DDR3 RAM. However the generated memory address size ist 27 bit and not 22 as expected with the memory size configurati...
NurAida_A_Intel
7 years agoHi Sir,
Good day to you.
May I know if you configure any 27 bits in your design (maybe at high level) ? And do you observed any functional/simulation failure with this generated memory address size of 22 bits?
NAli1
