YJing8
7 years ago@Intel support: ask a question about openvino and DLA
There are three different locations about the usage of model. 1. DLA architecture generator generate xxx. prototxt 2.The file used by linux command line is xxx. aocx and then programmed into the ...
JohnT_Altera
7 years agoHi,
It will depend on which model you are running. If the layer is able to executed in FPGA then it will be performed in FPGA.
You may run the "Per Layer performance" in order to understand where the layer is being performed. You will need to modify your host code in order to derive the model to run on specific location.
