YJing8
7 years ago@Intel support: ask a question about openvino and DLA
There are three different locations about the usage of model. 1. DLA architecture generator generate xxx. prototxt 2.The file used by linux command line is xxx. aocx and then programmed into the ...
JohnT_Altera
7 years agoHi,
You understanding is correct. You may also understand more on this from https://www.youtube.com/watch?v=UNoEflEM2IQ.
- YJing87 years ago
Thank you very much.
One more question. I read the source code of openvino and get the information that Cldnn already support about fifty primitives.
(1)Whether all of those primitives are implemented by FPGA?
(2)If some primitives in DNN can be merged in FPGA, that is the first primitive's output can be the input of the second primitive, how to write the source code and see the compiler result?
