YJing8
7 years ago@Intel support: ask a question about openvino and DLA
There are three different locations about the usage of model. 1. DLA architecture generator generate xxx. prototxt 2.The file used by linux command line is xxx. aocx and then programmed into the ...
JohnT_Altera
7 years agoHi,
The prototxt for FPGA will only provide the information on what is available in the FPGA and depending on what Model you are running. If the function can be performed in FPGA then it will be run in FPGA and if it is not able to be performed then it will be run in CPU. The FPGA will not have any architecture but just the function that is able to performed convolution and other features depending on which bitstream is being programmed.
The OpenCL API is only contain the driver to interface with the FPGA. OpenVINO will communicate with the driver where it will send the data to FPGA if it need to be performed in FPGA.
