ADua0
7 years agoIntel opencl report
In the report generated of my opencl kernel, in the area analysis tab of the report I see one line which gives resource utilization for " No source Line", like the one I have added below. I cannot un...
EBERLAZARE_I_Intel
7 years agoHi,
Was your compilation run successfully? Was there any error or warning messages?
- ADua07 years ago
Hi , yeah I was able to compile and deploy successfully but I do not understand about this resource utilization
- HRZ7 years ago
"No source line" refers to cases where some resource is being used for operations that do not necessarily map to any line in your code; e.g. registers and FIFOs used to balance the latency of pipeline stages. However, such large area usage in "No source line" is likely the result of a bug. Try to generate the report using a newer version of the compiler and you might get the correct location where those resources are being used. Older versions of the compiler (before 18.0) have a lot of such bugs in the report.
