ADua0
7 years agoIntel Opencl FPGA channels
I have a Opencl design which requires use of Intel opencl Fpga channels for communication between two kernels. I need to know what factors should decide about the channel depth ?
- HRZ
The main factor would be the amount of mismatch in the rate of writing into the channel and reading from it. If these rates are expected to be similar in both of your kernels, then a shallow depth of a few indexes (<20) will suffice and will not use Block RAMs either. If, however, the rate is expected to be very different, then you should keep increasing the depth and measure the performance to see when the performance will become stable.
- DongWang-BJTU
The compiler will change the depth during compilation, maybe that why the behavior is not what you have expected.
