Intel opencl Dynamic profiler report
By Index calculation, because I am doing inside the array only I am not sure it will be pipelined or not ? Is that correct to say that inp[a*b + c*d + e] also results in pipelined index calculation ?
By achieving 70-80% of utlization you meant for your test cases right ?
Currently I am performing my results using profiler only, which I achieve ranging between 255- 270 MHz, but even without profiling (in previous cases) not much difference. Should I expect major like (10-20ms) of performance impact because of compiling code without profiler?
I got confused by above comment, because in the previously in same thread you suggested to have 8 read and 8 write ports that helps in solving memory contention from having 16 read and write ports. Can you please clarify that?
Also , based on previous suggestion I changed to having 8 read and 8 write ports, and I am able to achieve better performance for similar resource utilization.
