Intel oneAPI DevCloud - FPGA Arria 10 exception
I've got a workload that consists of oneAPI DPC++ code. The code works correctly with oneAPI gold release on CPU and GPU devices.
Now I want to test it on Arria 10 in DevCloud. Compilation is successful, device selection and memory allocations work fine. The device I'm selecting for SYCL kernel computations is:
pac_a10 : Intel PAC Platform (pac_ee00000)
But on first computation (in my case 'parallel_for') I'm getting exception:
"SPIR-V online compilation is not supported in this context -59 (CL_INVALID_OPERATION)"
The same code works correctly also for FPGA emulator:
Intel(R) FPGA Emulation Device
What needs to be changed for the real FPGA device to get it running?
Any help and suggestion is welcome. Thank you in advance.
Tomasz
1 Reply
- AnilErinch_A_Intel
Hi ,
Please check the video link below on getting the procedure to run Oneapi on FPGA hardware.
https://techdecoded.intel.io/quickhits/introduction-to-using-fpga-on-intel-devcloud/#gs.uubqt6
Thanks and Regards
Anil
