Intel OneApi and Stratix 10 GX MMD MMD JTag problem
- 5 years ago
Typically you would program the FPGA via JTAG once and after that, run-time reconfiguration should happen via PCI-E. You can manually reconfigure the FPGA via JTAG by using the following chain of commands to extract the .sof from your .aocx file (replace text between ** with appropriate names):
aocl binedit *aocx_file* get .acl.fpga.bin *bin_file*
aocl binedit *bin_file* get .acl.sof *sof_file*And then run quartus_pgm to program the FPGA (@2 points to the second device in the JTAG chain):
quartus_pgm --mode=JTAG --cable=1 -o "p;*sof_file*;@2"
Then do a reboot and after that PCI-E-based reconfiguration should work if your BSP has been created correctly.
Hi ,
Hope the community discussion was useful and the issue is resolved.
Just to add on please find the knowledge base link below for similar JTAG errors
Thanks and Regards
Anil
