Intel HLS compiler does not find includes
- 3 years ago
Hi Aik
Thanks for your time and the attempts to help me.
Finally I found out what the problem is and it is going in a completely different direction than you tried to help. Unfortunately I must say the Intel documentation for the HLS compiler has a lot of room for improvement!
The problem on my side was at different locations:- I had to install the latest Quartus version. I was not able to get it run with Quartus 18.1 which I am currently using.
- I had to download the latest HLS compiler 21.4. The one which comes with Quartus 18.1 does not work on my computer. I was still not able to correctly run the init_hls.bat file.
- I was using Windows Power Shell as the command prompt, but this is not working. You need to use the normal command prompt to get it run.
However, in the end the following link helped me a lot to solve the problem:
https://www.macnica.co.jp/en/business/semiconductor/articles/intel/127029/Best Regards
Paba
Hi Aik
I'm now one step further. I now have downloaded and installed a new version of Quartus, including HLS compiler. I'm now runnning on:
- Quartus Prime Version 22.1std
- Intel HLS compiler version 21.4
When running the init_hls.bat I get the following result:
After now successfully running the init, I tried again to run the 'counter' example from the HLS compiler installation. But I still get the same error when running the build command:
Best Regards
