Paba
3 years agoIntel HLS compiler does not find includes
Hi everyone I am new to HLS and doing my first steps with the Intel HLS compiler. I am using Intel Quartus 18.1 which comes with an integrated HLS compiler and also provides with samples for people ...
- 3 years ago
Hi Aik
Thanks for your time and the attempts to help me.
Finally I found out what the problem is and it is going in a completely different direction than you tried to help. Unfortunately I must say the Intel documentation for the HLS compiler has a lot of room for improvement!
The problem on my side was at different locations:- I had to install the latest Quartus version. I was not able to get it run with Quartus 18.1 which I am currently using.
- I had to download the latest HLS compiler 21.4. The one which comes with Quartus 18.1 does not work on my computer. I was still not able to correctly run the init_hls.bat file.
- I was using Windows Power Shell as the command prompt, but this is not working. You need to use the normal command prompt to get it run.
However, in the end the following link helped me a lot to solve the problem:
https://www.macnica.co.jp/en/business/semiconductor/articles/intel/127029/Best Regards
Paba
Paba
3 years agoDear Aik
Thanks for your reply. Please find my answers to your questions below:
- I use Quartus version 18.1
- I first had Visual Studion 2022 installed on my computer. To meet the requirements for the HLS compiler I did install additionally Microsoft Visual Studio Professional 2017 (version 15.9.55)
- The following screenshot shows the output of the init_hls.bat:
It looks quite different from what is shown in the document picture. But I'm not sure if this is the root cause of my issue.
Thanks for your help!
