SÖzdo
7 years agoIntel HLS Compiler - BEGIN Failed - Compilation Aborted.
I have download and installed Quartus Prime 18.1 Standard Edition / Microsoft Visual Studio 2010 / Model Sim - Intel FPGA Starter Edition and followed the steps given in HLS Compiler Getting Started ...
AnandRaj_S_Intel
7 years agoHi,
- Run the command perl --version on your command prompt, if it gives you an error message you probably need to add an entry to your PATH environment variable.My Computer and select "Properties", then click on the "Advanced" tab and select "Environment Variables". Under your User variables, click "New", and create a variable named Path with the value C:\strawberry\perl\bin
- Also try by installing latest version of perl.
Anand
