Pan
6 years agoIntel HLS (20.2) - problem with compiling more than 2 inputs writing into 1 output (one at time)
Generic functionality of component splitter, which can be seen in the attached picture.
Basic functionality of the request part:
Read mi32_in input and forwards it (based on address) to the rig...
Pan
6 years agoI have just discovered that frequency plays important role in case of splitter with more than 2 connections. Basic frequency I used is 100 MHz and component properly works at 10 MHz. But the goal is at least 250 MHz. If you have any advice about better fmax, I will be happy to hear it.
Still, it doesn't answer why more spaces in code between line 186 and 188 helps.
AnilErinch_A_Intel
6 years agoHi ,
Please find the fixed code attached.
Thanks and Regards
Anil
