Intel HLS (19.4) - Not supported device family except Stratix 10
- 6 years ago
I am able to compile the example design in HLS compiler v19.3 and v19.4 and could not duplicate the error as shown on your side.
It seems like the problems is cause by the device files are not installed correctly.
Could you try to reinstall the Arria 10 device files?
I had test the design code for "design" file and "example" file you uploaded.
I could see the compilation for both files by HLS compiler v19.4 are successful by using the command make intel_sim and make intel_cosim. The results show in the attached file.
Also, I am able to run full compilation for the quartus_compile.qpf file as well.
May I know the information for foo_internal_inst file? This is because in the foo_generation.rpt file,it does not show the "foo_internal_inst" on my side. Also, I do not have this file in my directory.
Please let me know if I working in the wrong direction.
