Intel HLS (19.4) - Not supported device family except Stratix 10
- 6 years ago
I am able to compile the example design in HLS compiler v19.3 and v19.4 and could not duplicate the error as shown on your side.
It seems like the problems is cause by the device files are not installed correctly.
Could you try to reinstall the Arria 10 device files?
I had try to compile the design by using HLS compiler v19.3.
I had error shown while compiling the design and the error as below:
main.cpp:71:7: error: no member named 'launch_always_run' in namespace 'ihc'
ihc::launch_always_run<my_task>();
main.cpp:71:34: error: expected expression
Also, I had look into the design and you have mentioned there show an example from Intel as comment.
Could you direct me to the example provided by Intel or provide me the example name?
